Dodge Ram 99
13 years 10 months before #29214 by manual-mecanica
DODGE RAM 99 Published by Manual-Mecanica
convert a Dodge Ram truck model 99 Automatic in Standar that posivility there is a normal start or what would be the inconvenience
13 years 10 months before #29217 by manual-mecanica
Manual-Mecanica Response on the Re: Dodge Ram 99
Well ... the issue of change is no greater complication while using a Dodge Ram gearbox, the only thing that should be taken into account is whether the vehicle's computer has transmission or vice versa. If the transmission has nothing to do with the motor computer, it should not have a problem to start.
13 years 10 months before #29228 by manual-mecanica
It is true if the box has an electronic command by ECU, or the ECU takes parameters of it you will have gas and power problems, since the computer works in a state of emergency, you will not have problems, anyway if you put the mechanical box the vehicle the vehicle will walk anyway but I do not know if the gases and the power will be the necessary real.
