Trooper 90
13 years 8 months before #29099 by manual-mecanica
Trooper 90 published by Manual-Mecanica
: Ohmy: Someone knows where the connector of an Isuzu Trooper 90 2.6 is located on the computer says K is in front of the gear lever in the console already search and nothing someone knows thanks
13 years 8 months before #29103 by manual-mecanica
Manual-Mecanica Answer on the Re: Trooper 90
I have an izusu trooper that year the computer or ECU is in front of the gear lever between the front seats ...... is under the box to save things ...... I hope it serves you .....
13 years 8 months before #29106 by manual-mecanica
Hello, how are you
if you refer to the diagnostic connector, it takes it on the right side on the board next to the door carries a small window, there you inhabit it and connect it in that area,
and in other models you find it behind the glove compartment on the right side
greetings
13 years 8 months before #29125 by manual-mecanica
Hello ... I know the 2.6 trooper until 89 and what it has is a self-diagnosis that is activated by connection of two cables that are under the console of the gear lever ... between the two seats and on the computer ...
13 years 8 months before #29144 by manual-mecanica
thank you
