Passat 2000 1.8t
13 years 11 months before #28903 by manual-mecanica
Passat 2000 1.8T published by Manual-Mecanica
Hello, what happens to me with my passat with 160,000kms that the oil pressure light turns on even when I changed the oil 6000km?
13 years 11 months before #28905 by manual-mecanica
Manual-Mecanica Answer on the Re: Passat 2000 1.8t
You should be careful could be a symptom that your oil pump is failing, if it is completely damaged Scan your car, and take it to a good mechanic, since the VW are somewhat complicated ... greetings ..
13 years 11 months before #28907 by manual-mecanica
Good that motor mounts your passat, in the 140 hp I think I remember that the oil pump is moved by an axis that is similar to an Allen key that connects with the compensator tree, well, because the problem lies in that axis that on the side of the compensating trees it is spent and does not move the oil pump causing the lack of pressure and almost certain It is with a pressure clock that is placed in the pressure acorn
13 years 11 months before #28909 by manual-mecanica
The first thing you should do is install a watch that measure oil pressure and see what indicates you. If the pressure is low, you have to begin to rule out problems such as changing the oil shock, etc.
