Sometimes nothing starts (help) (solved)
13 years 11 months before - 13 years 10 months before #28869 by manual-mecanica
Sometimes nothing starts (help) (solved) published by Manual-Mecanica
That such comrades have a Supreme Supreme Supreme ODSMobile 3.1 1996, which sometimes does not want to start absolutely anything, the starter engine does not make any noise or anything, only a relay is heard, I have to leave it for a while and start as if nothing had happened, what could it be?
Salu2.
Latest edition: 13 years 10 months before by .
13 years 11 months before #28870 by manual-mecanica
Manual-Mecanica response on the Re: Sometimes nothing starts (help)
But when you try to turn on, it fails as if the battery were downloaded?
13 years 11 months before #28871 by manual-mecanica
If it seems that I was downloaded, but turns on the entire board.
13 years 11 months before #28872 by manual-mecanica
Check the accumulator tries with another to also Czech that Aiga Senal from Start if I did not work the problem is in the march B)
13 years 11 months before #28873 by manual-mecanica
Ok, the problem is electrical, it can be the starter switch, this is a piece that is located in the ignition (I mean where you put the key), this piece is responsible for spark That, I have a corolla, in my country the spare parts Toyota are worth an eye of the face, so the solution was to put a relay to the ignition, and look I told Adioooos to that cancer that my car had.
Eye before any expense take it to an expert, I recommend a non-mechanical motor electro-auth, since the damage is electric ... Greetings friend.
Source:
I have a
full -time and mechanical systems Ing student experience with my car ..
