carburization
14 years 3 weeks before #28814 by manual-mecanica
Carburetion. Published by manual-mechanics
Hi, I have a 1995 Orion and I can't get the carburetor to work properly. It's not giving me the speed it did three days ago, and it feels sluggish. I don't know if it's a timing issue or a problem with the accelerator pump. Also, it won't start on CNG, and when I do manage to get it running, it runs poorly. I don't know what the problem could be. It starts right up on gasoline without any problems, and then runs fine, but it lacks acceleration and top speed; it struggles to reach 80 km/h, which it didn't do before. I'm baffled. Thanks in advance.
14 years 3 weeks before #28815 by manual-mecanica
Manual-mechanics' response on the topic Re: carburetion
Just ask whoever did the conversion, that's all. There must be something covered up or defective
14 years 3 weeks before #28816 by manual-mecanica
What did you do to it? Just adjust the carburetor? Why are you saying it's a carburetor problem?
14 years 3 weeks before #28853 by manual-mecanica
Only the auxiliary camshaft seal was replaced. Before that, everything worked fine; it might idle roughly sometimes, but the car was a rocket. After the seal was replaced, the problem started, and that's when I thought it could be the carburetor, since the timing seems correct. You turn the key and it starts right up and idles fine
14 years 3 weeks before #28854 by manual-mecanica
Thank you, very kind of you
