Po 116 Jetta Code 2003 Help
13 years 11 months before #28712 by manual-mecanica
Po 116 Jetta Code 2003 Help Published by Manual-Mecanica
Greetings friends, I have a 2003 Jetta 4 Cil Motor 2.0 MFI, for a long time I had the Chek Engine, I was the Autozone for the scanning, throw Po 116 code, the machine does not overheat, there are no antifreeze leaks, someone knows what fails it can be, the Tempo sensor .. or the water pump ..... Thank you I would appreciate your help. greetings
13 years 11 months before #28752 by manual-mecanica
Manual-Mecanica Response on the topic Re: Code Po 116 Jetta 2003 Help
That code is an indicator of the motor temperature sensor, in general, it can be a fault in the cooling system as you say the pump but it is usually the fault of the temperature sensor
13 years 11 months before #28753 by manual-mecanica
The code is about the temperature sensor, you can use a multimeter to check its stat
13 years 11 months before #28754 by manual-mecanica
I was going to say the same thing the friend said ... with some click cables you are testing it with a multimeter already measured the engine temperature The sensor resistance has to lower if it is not so you have to replace it!
13 years 11 months before #28759 by manual-mecanica
Thank you friends, I will test the data that indicates me, and I will notify you what happened, and if there was a need to change the sensor, and if Chek Engine is erased ... thanks in advance .....
