Mazda BT-50 2008 Mazda Caja
13 years 11 months before #28676 by manual-mecanica
Mazda BT-50 2008 Mazda Box published by Manual-Mecanica
I have a problem with the gearbox of a Mazda BT-50 2008 when I put the changes it costs that they enter and when they enter I can not disengage the changes that may be will be the problem of the press and the album
13 years 11 months before #28701 by manual-mecanica
Manual-Mecanica Response on the Re: Changing box of a Mazda BT-50 2008
If with the detained vehicle the marches come well then the problem is from the clutch kit spent defective press or bearing, but before check the drive system if it is by piola or by pump to rule out these components.
13 years 11 months before #28797 by manual-mecanica
Well, the precion of the clutch system is fine even with the new pumps and disassemble the gearbox and the press is overheated I hope this is the problem I will change the entire full kit, the strange thing is that recently (1 month) the kit has changed the kit
13 years 11 months before #28805 by manual-mecanica
New or re-manufactured ???? The clutch (clutch) is hydraulic? You can try the simplest and economical, check if the system has air in the Clutch pipe.
