Jetta A4
13 years 11 months before #28468 by manual-mecanica
Jetta A4 published by Manual-Mecanica
Good afternoon you acavo to acquire unjetta a4 model 2001 The car is almost perfect the question is that it is very little chaparito in front and I
want
13 years 11 months before #28476 by manual-mecanica
Manual-Mecanica Response on the Re: Jetta A4
Reinforced ???? Mmmmm only that you want to put on a cousin truck, with which the originals buy is sufficient, they probably brows it, asks in a polishing or a specialized refactionary for VW, it is not very expensive.
13 years 11 months before #28487 by manual-mecanica
hahajajaja pineda as you tell him that hahaha, well actually just buy the originals but if he still stays chaparrita you can only the cars, of course the suspension I assign you if hahahaha is a little hard.
13 years 11 months before #28498 by manual-mecanica
Hi Sichaparito means that the suspension was lowered, what you should do is place the suspension springs (spirals as we call them in Argentina) and original shock absorbers. It is convenient to change the spring+shock absorber.
If you only change springs, the shock absorbers work at another height and not correctly.
Greetings from Moron Argentina
13 years 11 months before #28515 by manual-mecanica
Thank you very much, if Chaparrita is short, what happens is that I ask in the suspension workshop and that said that I saw that putting reinforced, but I thank you very much, I loom new shock absorbers and springs, a thousand thanks.
