My goal temperature
13 years 11 months before #28457 by manual-mecanica
MY GOL TEMPERITION PUBLISHED BY MANUAL-MECANICA
Hi, I wanted to share with you the pronlema I am having with my car, I have a 1.0 motor goal and since I bought it I have had a problem with the temperature, it is permanently in the 96-97 degrees and after it turns on the electro low to nineties. I have already changed radiator, water pump, cylinder lid joint, hose, liquid, and keep walking at the same temperature, I don't know that it can be, if someone can guide me, because the mechanics that I have taken it have told me that they do not know what it is. I thank you to help me.
13 years 11 months before #28462 by manual-mecanica
Manual-Mecanica Answer on the Re: MY GOAL TEMPERITION
Hello, how are you, look what can be is that you have the circuit a bit covered somewhere and does not circulate well, the 1000 goal has the heating radiator running in the same circuit as the engine radiator, you would have to check that it works correctly. I spent a 1000 that I had and lifted temperature.
Another would have to do that the bulb is working well and it is correct, but I suppose that the mechanics will have seen.
13 years 11 months before #28477 by manual-mecanica
In addition to that that were measured, you think about replacing the radiator plug or recovery tank ...;)
13 years 11 months before #28486 by manual-mecanica
Friend Volkswagen work between 97 and 98 degrees of temperature that is normal, it is not that what you want is that the electro starts before only changes the temperature bulb that they bring is 98 101 I think I put a smaller one and nothing complicated.
13 years 11 months before #28489 by manual-mecanica
Thanks for the answers now what I will do is change the bulb of the electro fan for one lower, the heating is annul I had chopped a little and there lost pressure.
