Turn on hand brake panel indicator
14 years 3 weeks before #28364 by manual-mecanica
Light indicator of the hand brake panel published by Manual-Mecanica
Estimated:
I need your help, the panel indicator that is activated when the handbrake lever is lifted, although this is the position deactivated. Please give me any scope.
Thanks in advance.
14 years 3 weeks before #28369 by manual-mecanica
Manual-Mecanica Response on the Re: Turn on the handbrake panel indicator
When it is so, it is because it lacks brake fluid in the central brake pump, this is because the pills are wearing and when adjusting the same low the level of the pump deposit, the level of the liquid to maximum must You have to see the swich that is next to the handbrake lever if you are not stuck or stuck
