Sentra B15 2.0 Mod 2001 Motor No to turn it off
13 years 7 months before #28333 by manual-mecanica
I have a problem that I have not been able to solve my engine does not let it work when I turn it off, I change it, sens detonation, and we even lower the engine and we gave change to all the internal feet. It has less than 15000 km DS after the Over Haul so carbon discarded ... The Scaner does not mark any failure, revolutions in idle in eight hundred rpm. In fact, it makes small explosions when removing the foot from the accelerator running.
13 years 7 months before #28337 by manual-mecanica
Greetings friend, has symptoms of an injector is dripping, have done the injector test (drip and balance test), there is no exaggerated smell of fuel?, Check in case the gas pressure regulator also. Check that and tell us how it went.
13 years 7 months before #28338 by manual-mecanica
Hello. He does not stop, is that it takes to stand or what is there no way? It does it the same hot and cold? Give more clues. All the best
13 years 7 months before #28347 by manual-mecanica
Perhaps they have left him the direct fan or made some electrical repair before he gave the problem. They already checked if the voltage does not cut when the switch turns off, or if it remains for a few seconds while slowly lowers the turn.
13 years 7 months before #28350 by manual-mecanica
In fact, the failure does it in cold and hot has no more than the high flow filter, it has spark plugs Denzo occupies Mobil 1,5550 synthetic oil The fans have a year that changes them. In fact I am an enemy of Cafamex brand repairs, that is, there is nothing happens. I prefer to change the piece and do not miss me and I travel a lot. In fact I will lower the complete rail on Tuesday to take a laboratory and see what happens. New Battery Gel Optima yellow CJA, regulator and new three weeks, but the failure already has a good time. I think the same as it is the gas pressure regulator but they do not sell here and the Nissan Pa ending up does not have it. Greetings I am in contact.
