Thank you very much, I understand, if I knew that the brushes did not square me (choto, carbon do you mean to the brushes? 1, (I put a TB photo:
Terminals 2, and 3 are those of the double connector, the 2 as you can see direct to a fuse of the box next to the battery, and direct to battery positive. This is marked with LG in a workshop book of a posterior micra, that of the K12 engine, mine is the K11, and the other, the 3 is marked as Lque Vá to the regulator, and I see the regulator to the passing panel through the 10A fuse under the steering wheel, and then goes to the contact key.
What I do not understand how 2 terminals of the connector to a brush, the refusal, (or less positive) ...........
The diodes are not loose, if the 3 diodes have measured them from the end of each phase to the same nut of connector 1. and the other 3 from a threaded asparagus, which then passes the lid, negative bone, to the same ends of windings. The status winding has star connection, verifified.
So, I think the alternator is fine, I will mount the alternator again, hope it is an excessive tension drop in the clear cables. To measure tension, what will be the cable that loads the battery, the fat of the connector 1 (I believe that yes), or the 2 the LG, which goes with one of 10a ?, Because I disconnect, start, to see what tension there is.
The alternator is a Hitachi12v65a. Let's see if I find the scheme by INET.
The new scheme, the negative broom not connected, since I don't know, nor connectors 2, and 3, the rest is fine.
E1 would be a brush (direct of the battery positive), and the one next to the right, I do not know if you know how it is connected to terminals 2, and 3, there is no continuity, we go the Tester does not whistle, there is some electronic component interspersed.
Thank you so much
All the best
