Front suspension
13 years 11 months before #28263 by manual-mecanica
Front suspension published by Manual-Mecanica
Greetings. I have problems with the suspension of my vehicle, a Toyota Corolla 95. It happens that the left front shock absorber hits very strong even in small holes of the pavement. I have already changed the shock absorber 2 times and the spiral once but the pounding is still given. I do not believe that the shock absorber has leaks because there is no precure liquid. The error or fails is not given. Please help.
13 years 11 months before #28280 by manual-mecanica
Manual-Mecanica Response on the Re: Front suspension
It may be that the noise does not come from the shock absorber and that it is from the suspension tray, and if it is a shock absorber you only have the option that this evil armed or bad the casoleta, in addition the bushings of the stabilisator bar in poor condition make a similar noise, as well as the wakes. sludge
13 years 11 months before #28286 by manual-mecanica
hello! I would recommend lifting the car until the floor wheel and wearing a long lever to simulate the movement above and down putting the lever under the wheel so it can make sure where the noise comes from .... Ready
13 years 11 months before - 13 years 5 months before #28288 by manual-mecanica
Hello, my car had a similar problem and they advised me to visit the mechanic as soon as possible to avoid major problems.
Latest edition: 13 years 5 months before by .
13 years 11 months before #28298 by manual-mecanica
It can be the tablets or buses of the tables
