The oil indicator light is turned on
13 years 11 months before #28253 by manual-mecanica
The oil indicator light is turned on when the engine has spent more than half an hour on, but only when the revolutions are low (at a minimum) at the time of accelerating the engine the light goes out
13 years 11 months before #28259 by manual-mecanica
Manual-Mecanica Response On the Re: the oil indicator light is turned on
Check the oil level, and check the km that you have left to change it.
That is due to lack of level or oil pressure that when taking temperature becomes less dense and lack of pressure.
13 years 11 months before #28267 by manual-mecanica
I analyze a little, it will not be lost compression from the oil pump? would this cause oil to be lost? Why the oil level is normal
13 years 11 months before #28269 by manual-mecanica
What brand and model is your vehicle
13 years 11 months before #28272 by manual-mecanica
I had a similar case in a 4 -cylinder American Ford and the problem was the new oil filter. Replace the problem for another of another brand and the problem is over. I hope it helps you
