IBECO motor injectors
13 years 11 months before #28211 by manual-mecanica
IBECO Motor Injectors posted by Manual-Mecanica
I have a problem with the injectors of an Ibeco engine, it could be that they produced a very strong noise
13 years 11 months before #28226 by manual-mecanica
Manual-Mecanica Answer on the IBECO Motor Injectors
Yes, when an injector nozzle is stuck when accelerating in the engine, a picket similar to that of a gipped rod or piston sounds
13 years 11 months before #28239 by manual-mecanica
You can be carefully loosening the pipe from an injector at the same time, when the noise ceases you determine in which cylinder you have the problem, if you want to be sure when you locate the fault exchanges the injectors to determine that it really is the injector
greetings
13 years 11 months before #28276 by manual-mecanica
Feliper is right is the simplest test to do and very, very, very effective, this effect is called a injector blow and looks like a valve and piston but it is not, the Mercedez usually occurs easily.
