Astra G camshaft sensor
13 years 11 months before #28251 by manual-mecanica
Manual-Mecanica Response on the Rera G camshaft sensor
The code would have to look at it because I did not write it down, and if the sensor is new and it is not the first time that a
new and defective piece is amount, I suspect that it is the sensor but I have no information on the values ​​it should give, it is as if
the signal was cut when it is heated.
I will have to try another sensor because I no longer trust.
13 years 11 months before #28252 by manual-mecanica
Look at the car distribution well, the problem is usually these cars in the crankshaft piñon and fails in cams sensor.
13 years 11 months before #28265 by manual-mecanica
That is very true I had the same problem with a B15 and it was that the distribution was out of time. The other thing is that it has valve time advance and your code refers to the sensor that controls the progress of valvular time. Give us the code to know what your fault refers to.
13 years 11 months before #28282 by manual-mecanica
First of all, welcome to the forum, I hope it will be useful, second all the answers that you give you are bench Contract or dilate the material and the signal is lost, if you can cool the sensor with a wet cloth or something when the fault is aga and if it improves it is the sensor
