Beetle 2002 Turbo 1-8 not accelerates
13 years 11 months before #28198 by manual-mecanica
Beetle 2002 Turbo 1-8 not accelerates published by Manual-Mecanica
I have a lack of acceleration, I already put the scanner and marked me in the acceleration body and the acceleration body was changed at that time the car no longer recorded any code in the scanner but on the board the focus of PCM is turned on, someone could help me or send me the diagram or the resistances that must be checked in the acceleration pedal towards the acceleration body.
13 years 11 months before #28207 by manual-mecanica
Manual-Mecanica Response on the Re: Beetle 2002 Turbo 1-8 does not accelerate
The focus that was on is the EPC, not PCM Primo, or am I wrong ??? Is your car automatic ??? AWW engine ???? Check it and let me know, because I am almost certain that your problem is the computer, but we do not get pressed, but it is aww your engine, I think it will be your problem. By the way of what country are you? Mexico, what part?
13 years 11 months before #28218 by manual-mecanica
If it is the EPC focus and the car if it is automatic, I write from Mexico City (DF) thanks
13 years 11 months before #28224 by manual-mecanica
Pass me the engine code, if it is aww, I think it is most likely that the problem is your computer, I have everything you get to check if it is your acceleration body, a damaged cable or your computer, send me an MP with your email to send you mine and send you the data ... or look for me on Facebook, Facebook.com/JCPINEDA87
Check that: it is the harness of the acceleration body, if you have the correct voltage, the signal of the compu ok, the problem is that it burns inside, here an example, it is very common in AWW engines, so it is important that you tell me if that is your motor code, by the car model I doubt this engine this engine occurred I believe only for the year 2001, yet it is not others, I imagine that you can be able to help.
And here the example of the burned computer.
We do not move forward, but it is important to know the code of your engine to send you the complete information ...;)
13 years 11 months before #28230 by manual-mecanica
Good morning, thanks for the aid has helped me a lot.
Tendo doubt where do I locate the motor code? The car is American. Thank you
