Hello forum: I have a problem with the car start
13 years 11 months before #28125 by manual-mecanica
It is a beetle of the year 1986 Motor 1600 CC, when the contact sheet opens does not rotate the starter engine, said engine has already been checked by changing the two speakers, coals, etc. Outside the car if it works but placed no, the contact sheet if it works, if there is current in the distributor, excellent fuel system, wiring has been checked all lights on, no ground cable has been found, I want to know what else I can do to start ...
13 years 11 months before #28128 by manual-mecanica
Manual-Mecanica Answer on the subject Re: Hello forum: I have a problem with the car start
Hello my friend, I comment that similarly I also have a vw flaws, which even happened almost the same but with a 6V. The inconvenience was that the starter solenoid or starter engine was safoid and lacked lubrication, apart from that the original switch was already in poor condition which caused a false contact, you can check the 2 things or check the cables !!! Haaa also the solenoid, inside it has a kind of currency, which when getting dirty usually gives problems, anything you tell me ok !!!!!!!
13 years 11 months before #28130 by manual-mecanica
Look, for the tests that have been done outside the car indicates that the Starter is in good condition, if the cables are already reviewed and its resistance is adequate, I recommend that you install a relay fences from the Starter to be this who makes electricity to the automatic
13 years 11 months before #28136 by manual-mecanica
If you give direct to the starting motor works?
You have checked with a tester who arrives the positive of the sheet
13 years 11 months before #28139 by manual-mecanica
Solution, if the engine works well as you say.
The first thing that Aria would be to place a positive cable
and consist of the start of the boot (eye be careful
) the bearing engine has to work, if
the automatic does not work, it can be for the heavy engine, the engine
could
throw to swell, the fields of the winding winding
of the starter of the start in poor condition or the bushings of the set spent
and therefore the reason the
field You are well explained by the other if the engine does not start,
greengine condenser
