electricity problem ??
13 years 11 months before #28062 by manual-mecanica
electricity problem ?? Posted by manual-mecanica
Greetings to the forum. I have a Ford Fiesta that has stopped receiving the sciences in two spark plugs. The cables are fine, and as far as I know, the coil rules for the 4 spark plugs or for any. Can you help me? thank you
13 years 11 months before #28091 by manual-mecanica
Manual-Mecanica response on the re: electricity problem?
If you lack a spark in two spark plugs, the most cause is that it is the coil, because the spark signal is one, not one for each cable, the 1y4 cylinder fails, or 2y3?
13 years 11 months before #28092 by manual-mecanica
Hello, if you have platinos, the axis is deviated corrects and that in all the edges there will be the platinum, do not forget to revive the posts of the distributor's lid in addition to the spark plugs
13 years 11 months before #28123 by manual-mecanica
Hello, look there, I would check the cable that sends the coil current, if it is well fixed if you raise the coil temperature ... because sometimes they heat up they stop working ... luck!
