Drops with my car
13 years 11 months before #27983 by manual-mecanica
PROBEMAS WITH MY CAR PUBLISHED BY MANUAL-MECANICA
My Mitsubishi Lancer 98 has petences problems by accelerating or hurrying it loses power and also begins to pull this very spending tall know what I should do to improve it
13 years 11 months before #27987 by manual-mecanica
Manual-Mecanica Answer on the Re: Provbema with my car
Your lancer is carburado or injection ... automatic or synchronous .... the fault is presented in cold or is always all the time
13 years 11 months before #28039 by manual-mecanica
It is with injection and is automatic, the problem is presented all the time in cold and with temperature
13 years 11 months before #28049 by manual-mecanica
Hi Alex: This fault is recent or do you have time like that?
13 years 11 months before #28073 by manual-mecanica
Well, it opened that several things for example, the current you have to see how the cables are, the spark plugs is spending because ethsa injecting more gasoline than it needs and there is a fault ... it opened that see how the injectors are if they are injecting well or are dripping to check the oxygen sensor ... if it is none of that it opened that going to the time belt. The same crankshaft since this tends to delay the vehicle ... but first empies so that I told you the easiest hehe
