Caliber 2009 does not turn on help !!!
13 years 11 months before #28157 by manual-mecanica
Manual-Mecanica Response on the Re: Caliber 2009 theme does not turn on help !!!
Greetings again I am glad to know that our comment served you for what you say the Peugeot brand I agree with the comment they gave you are much more expensive and difficult to maintain since their maintenance period is very small, I suggest that you buy something that in your country is working properly and that you have due advice because then that is what it costs more work I suggest that you do not take the brands of American cars. As you repair and do not come out so expensive since a European or Asian entails some details. On the at an atrocious side in the morning it is recommended to heat the car 2 min is enough I recommend you use multigrade oil or if you can the synthetic since the first clean the entire machine inside and maintains the necessary viscosity for the temperatures you drive that applies to any car I hope to continue supporting and luck in your selection of the new car
