Caliber 2009 does not turn on help !!!
13 years 11 months before #27908 by manual-mecanica
Caliber 2009 does not turn on help !!! Posted by manual-mecanica
Hello friends blogueros ... from peru .. I have a Dodge Caliber I know that I break connecting, I change it but now it simply does not turn on, the spark does not arrive !! After they rearmed the engine if it turns on the board but it is as if it had any alarm or ignition blocker, but I'm simply overwhelmed !!! Thanks for your help ..
13 years 11 months before #27910 by manual-mecanica
Manual-Mecanica Response on the Re: Caliber 2009 theme does not turn on help !!!
First that nothing do not hopeful the dodge is always so they are very good cars and of the simplest to repair I suggest you feel fault codes and therefore take out if that does not work Czech that the harnesses are well connected since with some pin that lacks it no longer works and also clean them with a light solvent since when it takes them to the workshop they fall to them. Be the case I hope it helps you the suggestions and do not despair will soon enjoy your car to keep taking care do not stop maintaining and bye and bye
13 years 11 months before #27949 by manual-mecanica
It is appreciated .. now I will talk to the workshop head and see how it goes ..
13 years 11 months before #28064 by manual-mecanica
Indeed, it is uncovered again and it was found that sensors were missing, thanks for all, in addition the strange cause of the connecting rod breakage (it is from 2009 !!) Apparently the oil pump is defective since it sends the rods half of the oil that I should send, so when my truck took out in the morning my truck in cold (and be without greater lubrication) sell it, there is no other, not trucks already ... I like the Peugeot 407 but I have read algal problems in spare parts ... well I will inform the blog !!!
13 years 11 months before #28111 by manual-mecanica
Better share a hiunday what is Peugeot blocked, BSI fails is a problem
