Mitsubishi L300 starts but stops
13 years 11 months before #27874 by manual-mecanica
Mitsubishi L300 starts but stands out by manual-mecanica
Hello anyone knows if the preheating box of the L300 can generate that not only does it not turn on but that the battery is consumed in 4 attempts to turn it on? It makes a very strange noise when I start and it does not turn on. greetings
13 years 11 months before #27891 by manual-mecanica
Manual-Mecanica Answer on the Re: Mitsubishi L300 starts but stops
The box itself would not be the problem but that the state of the battery, Deveria fugit
13 years 11 months before #27895 by manual-mecanica
If I understand that, the issue is that the battery is new and loaded in 12.30V ... that is the test and is in that, go down to 11V to the 3rd attempt to start, do you say that the battery changes anyway?
