Sumbido when I'm running
13 years 11 months before #27840 by manual-mecanica
Sumbido when I'm running published by Manual-Mecanica
: Angry: : Angry: Hello I have a Toyota Tercel from 92 aut. And it has as a sombid when I run that the faster I go the more raid it does not know if it is the axis or something the sombid is like wowowowowwwwwwow something like that is that it is difficult to explain look if anyone knows.
13 years 11 months before #27850 by manual-mecanica
Manual-Mecanica response on the Re: Sumbido when I'm running
Epale Pana, something similar happens to me and they are the bearing of the front apple, check to see if it is your case
13 years 11 months before #27852 by manual-mecanica
exactly are the bearings can be front or rear you advice that you change the same bone if it is 1 front change the 2 and if it is the same rear
13 years 11 months before #27886 by manual-mecanica
The Sumbid is usually a bearing is a very annoying noise that increases with speed and how it makes you pique an ear, it is as if you were to take off, just look like it sounds, and as Wolf says the torque changes the torque so as not to have problems.
