Ford Escort 1.8 TD Unstable idle
17 years 7 months before #2784 by manual-mecanica
Ford Escort 1.8 TD Unstable idle published by Manual-Mecanica
Hello everyone I have a Ford Escort 1.8 TD of the year 1997, the problem I have is that when the car starts, the engine begins to head as if it fails diesel, the engine sounds like sticking and the few seconds take off the noise and everything perfect, then after timeing when I leave it, I start it starts to go down as if it went to stop and then it is going on and then it is going on and then I do not Help serve what I have put.
17 years 7 months before #2811 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Escort 1.8 TD Unstable idle
Czech the admission multiple balvele, perhaps that is dirty that regulates the minimum march in idle and on.
17 years 7 months before #2815 by manual-mecanica
Verify the state of spark plugs and emptiness lines, the poor condition influences the idle
17 years 7 months before #2830 by manual-mecanica
You can tell me what the valve is, the car is from Gasail when you mean the spark plug wires, I do not know if those of the heater, which I believe that those of the heater do not influence the idle.
17 years 7 months before #2833 by manual-mecanica
Hello, I think you have a problem with the identification of the Ralati valve, Mira enters www.google.com the writer IAC Ford selects search by image and with the images that are sure to surely find a similarity with some piece installed either in the multiple of admission or in the acceleration body since the truth I do not remember where it is installed, once the locality is clean. The holes with a spray (sprinkler) that I used to linked carburetors you would find in any automotive parts store. You also remove the acceleration body and clean the interior with this same liquid, when you are cleaning the acceleration body that the cleaning liquid is touched by the TPS sensor mounted on the acceleration body, be careful also with the packaging both the IAC valve and the acceleration body.
I hope it is useful.
And if the problem continues, do not let it comment.
Mexico,
April 18 08
