P306 HDI Double Pump Connector and Refer
13 years 11 months before #27753 by manual-mecanica
DOUBLE CONNECTOR AND DOUBLE GASOIL P306 HDI PUBLISHED BY MANUAL-MECANICA
The car began to give problems that sometimes I did not listen to the diesel pump and therefore did not start. Remove the double relay that feeds the gasile pump located behind the switchboard and remembered it and the car started and I was walking several weeks with it until it failed me again. I have canceled the red button in case of overturn as if it were. I think I will have to change the cable beam that the reverse carries but I don't know where they are going. Can anyone help me? Thanks in advance. attached photo of the relay and connector that I speak
13 years 11 months before #27764 by manual-mecanica
Manual-Mecanica response on the Re: Double connector and relay pump P306 HDI pump
Hello, look at the fuse compartment in case some of them were oxidized or overheated ... a greeting
13 years 11 months before #27780 by manual-mecanica
I don't understand the question well, do you want to put the cables without the connector? or put the connector in another branch?
13 years 11 months before #27781 by manual-mecanica
I want to change the relay and cable beam that are cut in the photo because what is failing to me is also the relay connector and I would like to know where these cables arrive, if they are hooked to another connector or go straight to the pump and other components that move the rel. thank you
13 years 11 months before #27791 by manual-mecanica
Hello, I also have the same problem (Peugeot 306 HDI) the car stops for now wherever it is and I created insecurity.
