Mount a cylinder head ...
14 years 2 days before #27714 by manual-mecanica
Assemble Building ... Published by Manual-Mecanica
I am going to mount the Transporter button, the crankshaft draft comes with its mark on the steering wheel and gearbox, the pump has for its pin and the cams has to put a slot to put a horizontal spit with two gauges, my question is that in the manual it says that the cams have to be left for arriva and I have horizontal I have horizontal
14 years 1 day before #27745 by manual-mecanica
Manual-Mecanica response on the Re: Monta Curse ...
You just have to fix that cylinder is at crossing must be one or two, in one of them the two valves of being closed is not to step on the cam.
13 years 11 months before #28010 by manual-mecanica
He is already walking ... hehehe has cost me like five or six attempts for me to look perfect in the end and I went out to the second perfect, leaving the crazy cams since it is conico without a key, leaving it to press it the last, and nothing perfect jejjejje
I have put:
a valve admission
valves valves and
seals The same
butt without planning or anything as
a heater was a heater, new
oil and water
Cleaning of the EGR turbo and collectors
4 new hydraulic tales
