Citroen Saxo 1.1 loses a few drops of oil
14 years 2 days before #27678 by manual-mecanica
Citroen Saxo 1.1 loses a few drops of oil published by manual-mecanica
Hello I have a Citroen Saxo, 5 days ago and I have seen that on the front if you are in the driver's seat to the right, in the engine, it loses a few drops of oil when it stops, can it be something serious? I have also observed that on the road, there are times that it gives like some pulls, it is not very often but I do not know what it can be, I just bought it in a second hand is gasoline and if I am going to use the sauce more than the chicken, because I give it a ticket. Thanks if you can help me.
14 years 2 days before #27711 by manual-mecanica
Manual-Mecanica Answer on the Re: Citroen Saxo 1.1 loses a few drops of oil
Friend if it is on the part of the ditribuion you would have to put the XK tapas may lose by the retain of the crankshaft, if it is for oh it is very simple if you know how
14 years 1 day before #27734 by manual-mecanica
I have no idea to do it, I would have to take it to the workshop but it is to get an idea because in the workshop, they can tell me that you have to change half motor.
thank you so much
14 years 1 day before #27735 by manual-mecanica
Hello, see if the engine is a gasoline, you have to check well where the loss can be a retain that is spent on one of the eye oil circuits may be that the loss is from the edge of the carter not where the emptying plug is but closer to where it is adjusted with screws may be lazy if it comes out of clear there and for a drop of oil I do not think that there is a half engine to consume it and comes out. Leaya served my explanation thank you.
14 years 1 day before #27741 by manual-mecanica
They usually lose for the carter or carter plug, well you have not mentioned if the oil that falls is motor or cash
