Oil consumption
14 years 3 days before #27655 by manual-mecanica
Oil consumption posted by manual-mecanica
Almost in all the engines that are repaired, they consume oil, changing piztones, rings, repairing head and with rectified cylinders or failing and directed, I have wanted other types of rings options combining so that the rings are more adjusted to the cylinder and worked. In case someone can support me, thank you. sorry I have this problem in a Ranger 2.3 16 valves
14 years 3 days before #27656 by manual-mecanica
Manual-Mecanica Response on the Re: Oil Consumption
Ok first of all day. There are certain tests that you will have to do to determine first is the Compresometro Checar that are within the compression determined by the second manufacturer you have the test with the leak analyzer is part of the test determines whether the repair and armed really were correct since only by valves and rings are :)
14 years 3 days before #27660 by manual-mecanica
Friend .... What opening (light) left the rings or wheels in the cylinder ...
or your rectifier to what extent I leave the oil consumption very much.
If the cylinders polished it is a fact the oil consumption
14 years 2 days before #27671 by manual-mecanica
It is true oil consumption is either by rings or by valve seals, so it is of the utmost importance to stretch that there are no leaks to the outside are seen or not to the naked eye.
