Noise or Tracheteo of Valves of Kia Sportage 2000
14 years 1 month before #27651 by manual-mecanica
I'm having a problem with a rattling or clattering noise from the valves of a 2000 Kia Sportage (gasoline engine), and it sounds like a diesel engine. I was told it could be the hydraulic lifters or the oil pump. How do I test both, or where can I find the repair manual for this vehicle?
14 years 1 month before #27674 by manual-mecanica
If it were the oil pump, the light would come on even with a very small drop in pressure; tappets aren't tested, they're replaced
14 years 1 month before #27675 by manual-mecanica
Sorry, the oil you use directly affects the oil. If it has tappets, it has to be 10W40 or lower, never higher
14 years 1 month before #27815 by manual-mecanica
Thanks for the reply, I'll try changing the oil since it's 20W50, and it all started because they changed the cylinder head gasket and it's been making that noise ever since
14 years 1 month before #27816 by manual-mecanica
In many cases, once the lifters are repaired, they no longer function properly and need to be replaced. I also have one of those Kias, and I use that oil and it doesn't give me any problems with the 20w50
