Excessive, Cross Fox fuel consumption
14 years 1 month before #27521 by manual-mecanica
Excessive, Cross Fox fuel consumption published by Manual-Mecanica
The problem is that apparently the operation is fine, but suddenly a small pull is felt and the scanner does not mark any code, the excessive consumption of fuel was sudden, if someone could tell me where the fault could be, from the arrangeman, thank you.
14 years 1 month before #27523 by manual-mecanica
Companion I already happened once and it was a fight that car and it is unforgettable and everything is revealed to the temperature sensor that the ECM does not regit the fault. luck
14 years 1 month before #27526 by manual-mecanica
Of course, checking temperature sensor and what I remember I remember if it is what MAP or MAF brings if it brings MAF checks that the manga is not threctish as absorbed air from outside does not work properly
13 years 10 months before #31383 by manual-mecanica
Hello, I have a Crossfox 2011, a week ago I put 40 liters and it's already empty again !! I did only 260 kms, that's fine that I use the air to full, but it seems to me that consumption is excessive, do they know where I can lead to check? How did this problem solve? Greetings and thanks !!
