Hyundai 2.5 Turbo Diesel Motor Year 2006
14 years 1 week before #27425 by manual-mecanica
Hyundai 2.5 Turbo Diesel Motor Year 2006 Published by Manual-Mecanica
Hello, I have an Hyundai H-1 year 2006, 2.5 Turbo diesel engine and my problem is as follows; The cold game is very good, the engine is in less than 2 seconds, but when it reaches the working temperature I take as 15 seconds of start, at height over the 4000 meters accelerates like an animal and is very good but the slowdown is erratic it varies between 500 and 700 rpm. And the smoke of the exhaust is black, I turn it off and I turn on again and that is the strange, does not light Check Engine, all the maintenance per day and original fittings, the distribution belt reviewed 2 times and I no longer know what it can be. Other similar cars do not have this problem and reach 5000 meters high. Thank you :(
14 years 1 week before #27433 by manual-mecanica
Hi Alex192.
The fault of your machine seems filter, in the fuel circuit there are two, one primary that we almost do not lend the importance it has and the secondary, check the primary, the line of return of the fuel and the air filter. Luck.
Miguel
14 years 1 week before #27435 by manual-mecanica
Ok, I will check it, there is some post -permanent that the MAP sensor fails, which is installed in the admission multiple, a friend recommended me to change it. Thanks for your contribution, right now I will.
14 years 1 week before #27443 by manual-mecanica
It is important to check that the oil system is put air in the occasion to bite the celilers, but you can check the MAP sensor as you say but like Servilimit I do not think it is your problem, luck
14 years 1 week before #27445 by manual-mecanica
Injectors may be dirty and require specialized house
