ESP BAS and TRACTION LIBRUTION LIBRUTION 2008
14 years 1 month before - 14 years 1 month before #27363 by manual-mecanica
ESP BAS and TRACTION LIBRUTION LIBRUTION 2008 Published by Manual-Mecanica
I have a 2008 Jeep Liberty, the Lights of the ESP BAS and TRACTION CONTROL are permanently on, I made all the failures, wheel -up, tire pressure, direction steering wheel aligned, etc., etc. reset with a scanner, etc. And the lights remain caught. Please if someone can give me a hand in this problem. Thank you
Latest edition: 14 years 1 month before by .
14 years 1 month before #27385 by manual-mecanica
You do not put a problem gives the diagnosis machine, it is not just to review the system I think you have to go further and review the system with which the Lamina indicates, however I think it would be convenient
14 years 1 month before #27394 by manual-mecanica
Thank you, for your answer. The code that comes out is the C1090, I did what I advised me with the terminals of the battery and the 10 seconds again the 2 lights appear, I made the tires and the direction align and nothing. If you have any other idea please let it know.
14 years 1 month before #27411 by manual-mecanica
If I remember correctly, I say it will have to look for better I think that code is a fatal branch of parameter excess but I will find out to be sure and tell you that it is but I think I remember that it is a sensor that dies.
14 years 1 month before #27965 by manual-mecanica
Good afternoon I beg you to download the liberty manual that exists on our page outside that it is a good manual will help you reach the KJ Transmission page and read from page 15 to 44 will come to you everything I think I understand that it is the left rear sensor performs the prubas that come to you in the luck manual
