Vehicle does not start
14 years 1 week before #27306 by manual-mecanica
Vehicle does not start published by Manual-Mecanica
:( I have a Chevrolet Corsa Evolution 1.4 of 2005, I took out the crankshaft sensor (CKP) for being the cable peeled and exposed the wires fuck it but it did not work the wires, the wires were broken, I put a new one and now it does not turn on, it starts but does not turn on. If you can help me with the fault data, I would be very grateful
14 years 1 week before #27310 by manual-mecanica
Manual-Mecanica response on the Re: vehicle does not start
Amio I can be that sensonr carried 2 cables but the insulating lining had a mesh that is its land if it does not have that wire or lands
14 years 1 week before #27328 by manual-mecanica
The first thing is Checar if you have a spark in the cables, and make sure that all the lands that disconnected do not hold, the fuses fuses one melted one, but make sure the spark to saver where to go, if this is the problem is fuel that delimit the search field. Good luck and let us know.
14 years 1 week before #27347 by manual-mecanica
I have reviewed and there is no spark, everything is connected to the fuses and are good what could it be most?
14 years 1 week before #27348 by manual-mecanica
PD also note that installing a new sensor and still does not start there is no spark.
