Motor problems
14 years 1 week before #27269 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Problems
Good night friend send the car to scan and the scanner does not detect anything x that could not be scanned. He will lead to the mechanic and does not give the fault, pdv 20w 50 he when he starts is fine it is only at minimum that fails to start I have to be a lot so that I do not turn away x that if I accelerate little scratch but it seeks to turn off and stop without FURSA and I already tried taking off the senson of the cam and nothing removed or does not feel the difference canbie. car if you can help me, thank you
14 years 1 week before #27309 by manual-mecanica
But where they were scarce, it is more the scanner has to be for OBD2 if it does not have a signal in the ADL is a fuse that gives the signal for the gossip of the computer or mute !!
14 years 1 week before #27315 by manual-mecanica
Friend scanned her under the Bolante X where the most abajito conputer is the connector x oh, and all the fuses are well today the bolbi to carry the mechanic to the Tienpo and everything is fine but I get it when I turn it on when you have a first time and I release the croche without accelerating the normal spot but accelerate it a little more and in you. I continue to accelerate and spin as that in the acceleration did not tubed some injectors and nothing remains the same in the exhaust tube sounds pus pus as if the spark plug failed but it is not
14 years 1 week before #27330 by manual-mecanica
To ok the pus pus, it is of a cylinder failing this can be raised to the spark usually the spark plugs and cables to see how they walk, sometimes they bother even being new, being new,
14 years 1 week before #27332 by manual-mecanica
If my brother understands you what you tell me now you have to understand me, you can't be guessing? You have to look for a scanner that reads you what you have to solve vehicle failures
