Motor problems
14 years 1 week before #27423 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Problems
Friend the car the fault is removed a little but is throwing up in the exhaust tube and the umo is very afraid of gasoline and as you told me anteriorly, try the connectors of the injectors and all of the negatibo cable are fixed and all of the positibo cable flash another thing
14 years 1 week before #27439 by manual-mecanica
You have to put the diode, in the injector connector a positive pole and the other in negative, so that checks the pulse not one first and the other later, that the diode connected as it was an injector, now if the fuel smoke is much it can be from the temperature sensor, oxygen sensor, precion regulation, fuel pump, but put the diode as I told you to see how I flicker.
14 years 1 week before #27487 by manual-mecanica
Of course, friend !!
14 years 1 week before #27491 by manual-mecanica
You have to make a cylinder leakage test and so you will realize if there a problem with a valve, or with the cylinders package (cylinder cover)
14 years 6 days before #27506 by manual-mecanica
Friend the car is very aleled and now it is fine but very accelerated and boot a lot of gasoline leaves the four black bijias but that happened since it takes the senxor that ba stuck to the exhaust tube I think it is the oxyjen senxor but now it INTALLO and nothing I do not know if that could be that
