Oil leakage
13 years 8 months before #26967 by manual-mecanica
Oil leak posted by manual-mecanica
Greetings to everyone I ask my problem waiting for someone to help me. I have a Wagon R which is presenting a leak of oil for the rear stead of the crankshaft after repairing the engine, I have already changed the steope three times and the problem persists the leak is presented immediately and still does not explain that it can be happening. If someone can help, I thank you very much ...
13 years 8 months before #26970 by manual-mecanica
Manual-Mecanica response on the Re: oil leakage
Hello friend x What I see you have changed the steope a lot and do not last good the following reason is that it has a absional game in the Sigual, that is why the steepra does not have to lower the engine and check the benches, one of it has to be food and that is every time in croche if it is synchronous if it is automatical the follow of the fing top that you take them in speed makes the absol
13 years 8 months before #26972 by manual-mecanica
If I have certainly changed many times and it is an abnormal thing regarding your answer, the engine was recently made and we assume that he has no shell or bench problems in addition, we do not feel the engine when he is on although I think that what you tell me has a lot
13 years 8 months before #26975 by manual-mecanica
If he never sounded to you because the game does it, it is upset, you will see what the Sigañal comes out when it goes down the game horizontally verifies to be located in this way behind the Sigual I explain the box that way the box must place it, I do not put it the danper but go down it and the bank of the medium there or of the side of the side this meal and not the time well
13 years 8 months before #26976 by manual-mecanica
If I already understand what you want to tell me, I will review that after doing the job I tell you what we saw. THANK YOU SO MUCH
