Jac problem refine
14 years 3 weeks before #26908 by manual-mecanica
JAC REFINE problem posted by manual-mecanica
Hello everyone, I have a problem with the JAC refine in the Smañanas or when it is cold made smokeooooooo blue as if the injection point would be delayed and if you accelerate it a bit the motorcycle trembles.
CHARACTERISTICS
YEAR 2011
45,000 KM
CAMOON RAIL
TURBO INTERCCOLER
14 years 3 weeks before #26910 by manual-mecanica
Manual-Mecanica Answer on the Re: Jac Refine Problem
Compadre, the blue smoke is "burned oil" if it is only in the mornings or as you say, with a cold motor, it is by defective valve seals, when the engine is at rest (at night) the oil is passed through the retain
14 years 3 weeks before #26912 by manual-mecanica
I do not think they are the seals for the seals the engine would not be shaken that way when you accelerate it a little
14 years 3 weeks before #26923 by manual-mecanica
They can be two different things ... I know if it is safe it is the blue smoke is burned oil ...
