No Standart Platina Velocimeter Mark
14 years 3 weeks before #26900 by manual-mecanica
No Standart Plate Velocimeter Published by Manual-Mecanica
I do not mark the plate velocimetro,
I already put the speed sensor new and still does not mark
the speed
that another cause can be ..
14 years 3 weeks before #26909 by manual-mecanica
Manual-Mecanica Answer on the Re: No Standart Platina Velocimeter Mark
Before replacing a sensor, anyone that is, you always do the relevant tests to determine whether it works or does not work, what you have to do is with a multimeter to check the harness terminals (cables), you have to have an earth cable, another of 5V, and one signal (return to the computer), check that you have the ground signal, and the 5V of the computer, and that your sensor is generating a signal of: 5 - 5 - 5 - 5 - 5 - 5 - 5 - 0 volts (cycles of 5 and zero volts depending on the speed of the vehicle.
14 years 3 weeks before #26925 by manual-mecanica
Our partner is first reason, both the feeds and the lands of any sensor are corrovora, but something that is not to let `overlooked if it actually serves your board indicator, if you have a Scaner executes the targeta of the same and enters into testing actuators and you have that through the Scaner functions all the instruments of the SIVES board that the velocimeter does not work, there is no doubt that there is no doubt that there is no doubt that there is no doubt. NOTE ... ALVARIAS FORM TO WORK THE BOARD INDICATORS DEPENDING THE TYPE OF SCANER YOU WALLS TO USE
