Motor at the beginning, I worked with three pistons and then with explosions in the exhaust pipe, and then I stop working, any idea what is happening and what to do and what to do
Hello Juan Pablo, it seems that your problem is from the ignition system, you must check the coil, that the cables are in the order that corresponds well in the coil are written in order 1-4-2-3 (of the cables) also check the position of position of the crankshaft CKP. luck
