Problem with Blazer 95 Vortec
13 years 8 months before #26695 by manual-mecanica
Problem with Blazer 95 Vortec published by Manual-Mecanica
Hello friends greetings, I have a ignition problems of a Blazer Jimmi Mod. 95 With Vortec Motor the problem is the following I do not have a pulsation in spark plug I await your help
13 years 8 months before #26722 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Blazer 95 Vortec
Hello if you say that you have pulsation in the coil to the ditribuidor of there is lost, it is most likely that the rotor is damaged, (it can be cracked at the base and the spark goes to mass on the axis of the distributor)
13 years 8 months before #26725 by manual-mecanica
Good, I'm not sure if you have a pill inside the distributor? As described friends the rotor or the pill, until then.
13 years 8 months before #26959 by manual-mecanica
Friend I understand that spark arrives to the distributor. And the lid has been changed. So the only thing that remains is to change the distributor rotor
13 years 7 months before #28344 by manual-mecanica
:) Thanks colleagues indeed if it was the rotor thanks for your answers, they helped me a lot thanks again greetings.
