What type of engine oil use !!
14 years 1 month before #26505 by manual-mecanica
What type of engine oil use !! Posted by manual-mecanica
Good, I have a nuance of the year 99 with enough km .. I change the oil every 5000 km approx .. and it is up soon, I usually use 15W40 Valvoline, I would like an opinion if the viscosity is correct, and if they recommend a particular mark. I am from Venezuela.
Thank you
14 years 1 month before #26512 by manual-mecanica
Manual-Mecanica response on the re: what type of engine oil use !!
This viscity is well, Venezuela has no extreme temperatures, what you can do is put an oil for high mileage which contains special additives for engines with high mileage.
14 years 1 month before #26547 by manual-mecanica
It is true 15W40 This perfect brand is just opinion thing Valvoline is not bad at all, you don't change viscosity for a thicker because they get noise.
