Fuel air correction
14 years 1 month before #26212 by manual-mecanica
Fuel Air correction published by Manual-Mecanica
Hello friends, I have a problem with a 99 Hyundai Accent, belling at the exit about 400 meters and it is difficult for him to take speed after and the scanner says correction combustible air, what do I do? If you review flow, MAP, TPS, Catalitical Change Bencina and Filter Pump
14 years 1 month before #26481 by manual-mecanica
Manual-Mecanica Response on the Re: Air Fuel Correction
Hi Jotaele, can you pass me the code that throws your scanner ??? The Accent brings the purge seleenoid next to the gase butterfly and when it fails and it remains open, the problem is cylindrical like the fuel pump but it would be great to pass the scanner code, greetings, greetings
14 years 1 month before #26484 by manual-mecanica
hello! I think the problem can be in the octane that you are using ... Use super without lead gasoline and apply an octane additive ... and go! luck
