Electrovantillator problems for A/C
14 years 1 month before #26196 by manual-mecanica
problems with electrventilator for the A/C published by Manual-Mecanica
Help ... My Focus Zx3 Mod.2000 When my air conditioning turns on, the red zone is heated too much hasa, the first electro -ventrolerator, if the dream comes in time to turn on with the A/C is turned off at a few minutes of being on, I appreciate your comments in advance your comments
14 years 1 month before #26244 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with Electrovillator for the A/C
Hello, you will see the theme is to proceed first to verify pressures since if they are not adequate you can jump through the triaonera valve or pressure sensors, keep in mind that the first thing that connects is the bone fan discards this starts through the pressures and then it sees compressor thermal if it is variable or tri -shelter.
