Dodge Intrepid failure
14 years 2 months before #26144 by manual-mecanica
Dodge Intrepid failure. Posted by manual-mecanica
Hi everyone, I have a problem with this car. Only three cylinders are working. The compression is fine. I had it scanned and they told me the problem is in the ECU. I don't know if anyone has had any help with this; any advice would be greatly appreciated.
Thanks
14 years 2 months before #26149 by manual-mecanica
Manual-mechanics response on the topic Re: Dodge Intrepid failure
Have you checked if the ignition coil for that cylinder is working?
One way to do this would be to remove it, disconnect the others, install a spark plug, have someone turn the ignition on and the starter, and see if it sparks.
Have the spark plugs been changed?
14 years 2 months before #26151 by manual-mecanica
What year is it and what engine does it have?
14 years 2 months before #26178 by manual-mecanica
It's not the ignition coils because I swapped them, but what if they work? Oh, the vehicle is a 2002 V6 2.7 cc
14 years 2 months before #26180 by manual-mecanica
Czech suggestion the injectors .. Look if they inject or cut the current ... Possibly the computer ... or you can check the sensor of the camshaft of the side that are failing the cylinders ..... luck
