fiat stilo 1.9 JTD 80cv 2002 diesel
14 years 3 months before #26141 by manual-mecanica
Fiat Stilo 1.9 JTD 80hp 2002 diesel. Posted by manual-mecanica
Hi, I have a problem with this car. When I start it, it makes a squealing noise from the right side of the engine. A few months ago, the clutch was replaced, but not the dual-mass flywheel. It has 114,000 km. The timing belt was changed a year and a half ago.
Also, one day I checked the oil level with the car running, and smoke was coming out of the filler neck. Is this normal? Thanks for your help.
14 years 3 months before #26161 by manual-mecanica
Manual-mechanics ' reply on the topic Re: Fiat Stilo 1.9 JTD 80hp 2002 diesel
It could be a problem with the timing belt tension. The smoke coming from the dipstick is normal because the engine is running. The oil level should be checked with the engine off, otherwise the oil will be all over the engine and not just in the oil pan
14 years 3 months before #26162 by manual-mecanica
When they changed your timing belt, did they also change the clutch pulleys?
14 years 3 months before #26198 by manual-mecanica
Check the idler pulleys and tensioner of the auxiliary belt, as it is advisable to replace them when you change the timing belt
14 years 2 months before #26256 by manual-mecanica
Shortly after changing the timing belt, the service belt, a guide, and the pulley were also replaced. This was because when driving in second gear at very slow speeds, it made a very loud squealing noise
