My Renault Express Long White Smoke
14 years 1 month before #26081 by manual-mecanica
My Renault Express Long White Smoke published by Manual-Mecanica
Hello, Buelvo to bother the Renault Express engine and now I started it and out white smoke and I can not remember if it is why the pump is behind or advanced. They help me? thank you
14 years 1 month before #26082 by manual-mecanica
Manual-Mecanica Answer on the Re-Renault Express Long White Smoke
What repair did you do? It may not be scaras to the first to the first to the first, and if it is reiterated there are problems .. the vents of the valves may have changed them now! Maybe the fuel is mixing with the oil .. What happened to the engine before?
14 years 1 month before #26091 by manual-mecanica
He had blown the joint looted the lid and had the pre -curled pre -curren
14 years 1 month before #26096 by manual-mecanica
Hi Gustavo: If your Renault has hydraulic dumps, when starting for the first time, they are downloaded and you will feel noise to valves, it will smoke and fail a bit, until the bumps are loaded, if you can connect an oil pressure marker and have it in operation for a few minutes to see if the march is normalized, luck
14 years 1 month before #26098 by manual-mecanica
It happens that you have no vote has pastiyas,
