Tuning Fiat Brava Distribution 16 Valves
14 years 1 month before #25988 by manual-mecanica
Tuning Fiat Brava 16 Valves distribution published by Manual-Mecanica
Dear colleagues, I need information to put the Fiat Brava camshaft 16 16 valves 1998. Thank you.
14 years 1 month before #26110 by manual-mecanica
Manual-Mecanica response on the Re: set-up fiat brava distribution 16 valves
What type of engine is and what horses you have could give you a diagram of the distribution of distribution
14 years 1 month before #26114 by manual-mecanica
Hi is 1.6 with super torque El Brava engine.
14 years 1 month before - 14 years 1 month before #26122 by manual-mecanica
I do not mean that I will give you an example ok:
1.9TD 75CV Year 1987
And in the Tenica tab you come the model or type of motor
For example
Type 182a8000 diesel
Last edited: 14 years and 1 month ago . Reason: The image I uploaded isn't showing up.
14 years 1 month before #26134 by manual-mecanica
You will need a template set to position camshafts, without these elements will be lost of power and bad idle.
