Front end noise on a 2006 Ford Fiesta
14 years 3 months before #25979 by manual-mecanica
When driving, I hear a clunking noise in the front transmission. I've checked but can't find anything. The springs and shock absorbers were recently replaced. Could it be the stabilizer bar? Thanks.
14 years 3 months before #26014 by manual-mecanica
Manual-mechanics' response on the topic Re: Front suspension noise in a 2006 Ford Fiesta
I recommend driving on an uneven road to provoke the knocking sound, and when you hear it, gently press the brake pedal. If the noise decreases or disappears, it's because it's coming from the brake system. In that case, you should check the brake pad anti-vibration mounts to see if they are loose and/or readjust and lubricate (if necessary) the calipers.
