Corsa
14 years 1 month before #25818 by manual-mecanica
Corsa published by Manual-Mecanica
I am new in this forum, thanks for the welcome. I would like to make a consultation. I have a Corsa Classic 1.6, Mod 2008, Naftero. For a few days I started with the problem that stops suddenly, most of the time at low speed. He has been skullly and the failure is not found. He has changed gasoline bomb, spark plugs and everything remains the same.
I thank who can help me
14 years 1 month before #25837 by manual-mecanica
Manual-Mecanica Response on the Re: Corsa
If you stop, it can be electrical problem, you want to have to check the terminals of the battery first, and then bested with the coil the magnet captor, the ignition sheet, now if you look good at the time it stops, and you give us more data in cold or hot, in low down, etc. we can help you better.
14 years 1 month before #25839 by manual-mecanica
Hermanito, can be extinguished for several reasons. That the mace or land that they call is isolate, that the IAC valve is dirty and stuck, covered filters, that the velocimeter is not working.
14 years 1 month before #25889 by manual-mecanica
Thank you, then for more than an hour running, but not if you leave it regulating, the coil has changed it and remains the same, terminals and filters all new. The terminals are also fine. All that makes the mechanics (and I have consulted several) do not find the key
14 years 1 month before #25891 by manual-mecanica
Hello friend first tell me what year is the corsa and I can help you with pleasure
